How to Determine year on International Lo Boy
AndyC
03-08-2005 05:15:00
My grandfather gave me an Internation Lo Boy and I am trying to determine the exact year. I would like to restore to original colors, decals, seat, etc... The issue I am having is the reading serial#, it has been painted so many times it is hard to make out. Here are the numbers I do have. On the left side of the lower engine block are cast the following: 251341R79. On the left side of hydraulic cylinder housing are cast: 360719-R1. On the right side of the transmission are cast: 351686-R3 L 2 X. The shape of the hood and fenders resemble that of the Farmall. The name plating, International and Lo Boy, is in metal badges not stickers. The tractors has been many different colors, red, yellow/white, and currently a green. It looks like the base color of all these is red. Any help would be greatly appreciated. If a picture would help let me know I can send one.
Bigdog
03-08-2005 07:04:14
 Re: How to Determine year on International Lo Boy in reply to AndyC, 03-08-2005 05:15:00
If the serial plate is there but painted over you can use some paint remover and steel wool to gently remove the layers of paint down to the plate. It is aluminum so be careful how vigorously you scrub. The one number you gave with the X might be a casting code which would indicate the casting was made in 1952, but lo-boys were not introduced until 55 so that may not be a casting code. The metal badging would also indicate 55 or later.
AndyC
03-08-2005 14:05:05
 Re: How to Determine year on International Lo Boy in reply to Bigdog, 03-08-2005 07:04:14
Ok, I was able to clean the serial plate and I am coming up with serial# 12396. So what year does this put me in?
EZ
03-08-2005 18:43:10
 Re: How to Determine year on International Lo Boy in reply to AndyC, 03-08-2005 14:05:05
According to the Research and Info on the left side of this forum you have a 1960 Lo-Boy.
http://www.ytmag.com/cgi-bin/snlookup.cgi?mf=INT&md=Cub+Lo-Boy
