Removing Oil Pump
SuperCmore
03-02-2005 07:03:06
After the pan is off, how do you remove the oil pump from a Super C? Think Cmore's is warped as oil pressure not what it should be. I know you need to "true up" and install new gasket, anything else I should know about this job? Thanks, Cmore
Jay (ND)
03-02-2005 07:09:04
 Re: Removing Oil Pump in reply to SuperCmore, 03-02-2005 07:03:06
If it's the same as a C, there will be 2 bolts on the outside of the block holding it in. Under the bolts is a metal tab keeper that you need to bend back. I had to wiggle my pump a bit to get it out, but it will drop straight down. While you are straightening that plate, I would also replace the pressure relief spring. It's right there after you remove the plate.
TDK
03-02-2005 07:18:24
 Re: Removing Oil Pump in reply to Jay (ND), 03-02-2005 07:09:04
C and S/C are the same.
