tire pressure.....
gerty
02-28-2005 18:10:37
I have my F-12 and have scoured the manuals trying to find out the correct air pressure for the front and rear tires. No dice. Can anyone help?
JOSSETTE
02-28-2005 19:14:15
 Re: tire pressure..... in reply to gerty, 02-28-2005 18:10:37
didnt believe me--did ya
gerty
03-01-2005 13:49:42
 Re: tire pressure..... in reply to JOSSETTE, 02-28-2005 19:14:15
Sorry dude, you were right! What if the tires are filled, is the pressure the same?
JOSSETTE
03-01-2005 15:59:48
 Re: tire pressure..... in reply to gerty, 03-01-2005 13:49:42
10 lbs if filled the correct way
Allan in NE
02-28-2005 18:58:31
Gerty,
Don't have the same tractor as you, but I run my little H with 12 lbs in the back and 65 to 70 lbs in the front (got a loader on it).
Allan
CNKS
02-28-2005 18:50:25
Not familiar with the F series, but most rear tires of that era ran around 12-13. I don't know what effect the wider tires on the narrow rims on some of those might have had on pressure, though, if any. Front tires, until the bulge disappears -- about 30 psi.
gerty
02-28-2005 18:59:08
 Re: tire pressure..... in reply to CNKS, 02-28-2005 18:50:25
Thanks! I need to adust the 30lbs that I pumped into the rears. Oh well! Thanks again.
waltertn
02-28-2005 19:08:01
 Re: tire pressure..... in reply to gerty, 02-28-2005 18:59:08
The tires themselves should have the recomended air pressure on the sides. 30 pounds is way too much. There was a kid in east Tn killed a while back over inflating rear tires on a tractor.
