H steering shaft play
Gordo
01-24-2005 19:10:32
We discussed the play at the center support on the H. My center support was worn BADLY. The wormshaft had BAD wear spot on it. I bought the front bushing, and cut it lengthwise and pinched it down, Drove it in the center support.Took it to my good guy machine shop and he put it in his lathe and bored it to shaft dimension (.875) Then a little welding and grinding on the shaft and filing, and I have a tight fit. All for less than 25.00.
Gordo
