Farmall C Seat Bushings and Pet Cocks
railroadgoat
01-17-2005 16:59:57
What is used as spacer or bushing on seat with spring and shock absorber ?? I got new shock bushings, but front is real wobbly. Has about one inch pipe with maybe 1/2 inch bolt thru it. Sloppy.
Also, has 2 pet cocks on oil pan. What is each for ??
ronneee
01-17-2005 22:10:26
 Re: Farmall C Seat Bushings and Pet Cocks in reply to railroadgoat, 01-17-2005 16:59:57
do you wotk for the railroad...goat..are you on a yard job?
ronneee
01-18-2005 22:34:20
 Re: Farmall C Seat Bushings and Pet Cocks in reply to ronneee, 01-17-2005 22:10:26
i was an engineer for up in calif. now amtrak what part of ca?
Sam F.
01-18-2005 07:21:37
I work for Union Pacific in California. I am on a local going about 80 miles and then layover for 8 hours, then return home. 160 mile schedule. Are you railroad ??
jayw
01-17-2005 19:20:15
For the seat bolt what I did for mine was get a piece of 1/2 inch black garden hose then put it on bolt then a 7/8 inch black piece of garden hose over that and it took up the slack an its been fine for little over year now
CNKS
01-17-2005 17:56:14
I believe the part you need is called a seat support pivot rod, 355753R1. I believe Case-Ih still has it, as does OEM Tractor Parts.
S/C BOB
01-17-2005 17:42:00
THE BUSHINGS I HAVE TROUBLE WITH TOO. AS FOR THE PETCOCKS THEY ARE FOR CHECKING THE OIL, THE LOWER ONE TELLS YOU YOU ARE GETTING CLOSE TO THE RUNNING LEVEL. WHEN IT DRIPS OIL CLOSE IT AND BRING THE LEVEL ON UP UNTIL IT DRIPS OUT OF THE TOP THEN THE OIL IS AT THE PROPER HEIGTH...I HOPE THIS HELPS...BOBBY
