hit and miss engine
dexter
01-11-2005 13:08:37
i am a student for the vocational school in ohio and we got a 3 1/2- 5 hp hit and miss engine. it didnt run so i put the fuel tamk on and run a line to the carb. when we turned it over it has spark. so i tried to start it but everytime we do it seems to fire before top dead center and it just spins back the wrong way. is there any place to adjust the timing on it or any commits will really be help full thanks .
RonMI
01-12-2005 18:50:36
 Re: hit and miss engine in reply to dexter, 01-11-2005 13:08:37
Call Ed Deis at Hit N Miss Enterprises. He has alll kind of parts and will help you with your questions. His web site is: hitnmiss.com
KevinH
01-11-2005 16:04:23
I own several La and Lb engines. If I remember correctly, the mag drives off of the cam. So the direction of rotation on the mag is the same as the flywheel. Turn the engine over slowly with the plug wire off until the impulse snaps(this removes tension from the impulse spring). Then take the mag out being careful not to let the gear turn. Turn the gear one tooth in the opposite of the way the flywheel turns, reinstall and check. There are two marks on the flywheel:EX and DC. The DC mark should be straight up when the impulse snaps. You can email me if you have any questions.kharbin (at) nctv.com ..replace the (at) with @ Good luck Kevin
Fred Milner
01-11-2005 15:49:52
If it is an IH LB engine you will need to take the mag loose and move the timing 1 tooth at a time until you get it right. Just look at the position it is in now and the direction of rotation and ajust form that point. Mine did the same thing when I got it but workes good now.
george md
01-11-2005 14:30:40
Dexter,
On most one lung engines you need to hold the compression release untill it is spinning. It needs the enertia of the flywheel to carry it over tdc. I don't know what that one has for comp release, many of the small ones you just hold the intake valve open while cranking. Remove the crank and THEN let go of the valve.
george
Andy Martin
01-11-2005 13:54:05
You can retard the magneto just like on a tractor.
The magneto may need to be serviced though as probably has centrifugal advance which may be stuck in the advanced position. Unless someone has messed with the timing, I'd start with the advance.
Greg Bullough
01-11-2005 13:28:56
Try posting your engine under the Stationary
Engines forum on this board. This is IHC, and if our tractors hit-and-miss, it's usually
the sign of a big problem
