Getting grass out of gas tank
John M
12-27-2004 12:07:31
Had to put a better gas tank on my M,problem is somehow grass has gotten back behind the baffle and I cant get it all out.I thought I had gotten most of it out but there still is some in there and I dont think I can shake it out around the baffle.Any suggestions?
Dave NE IOWA
12-27-2004 19:35:00
 Re: Getting grass out of gas tank in reply to John M, 12-27-2004 12:07:31
It is pretty simple. Go to any hunting supplier and get a jug of double 00 shot, or even number 7 will work. Lead is cheaper than steel shot, throw it in and duck tape your tank to a spoked rear wheel of a tractor and go for a drive. It will tear it into dust size pieces. It is probably a little late in the season to plow all day if you would like to get her shinny on the inside. The shot is still good for a hundred more tanks or ok for a friend to reload shells with. Good luck Dave NE IOWA
El Toro
12-27-2004 17:10:20
Hi John, I used a wet or dry tank vacuum on that gas tank and I did the cleaning outside, no problem whatsoever. Hal
Bus Driver
12-27-2004 15:53:53
Gasoline fumes pulled through a vacuum cleaner hose may well burn when they reach the motor brushes of the vacuum. Get one of those "grasping fingers" tools and pull the grass out.
El Toro
12-27-2004 15:16:04
Hi John, I used a vacuum cleaner to vacuum rust and dirt from my gas tank. I used a cannister vacuum with a long hose so there were no sparks.
I couldn't get my big paw in the opening so I recruited my wife. I always used her to put those keepers in when I was reassembling a cylinder head. She complained that I was cutting her finger nails off. Hal
John M
12-27-2004 13:45:50
Good suggestions all and I will try it,except the mini cows;).I got this tank and it looked good on the inside.I did flush it out wioth water beforeI put it on and let it dry a few days beforeI put gas in it.It was only after a couple of hours of running did I find out thye grass was in it and at first thought one of my kids put it in there,but neither would have been able to get to it,young kids.I wish I had known the grass was in there before Istarted putting the ole gal back together.
RZ(WA)
12-27-2004 13:36:45
Good luck with this one :) Lye, Drano or Septic Tank root killer might work. Or just use it and install one of those cheap clear plastic fuel filters and have a couple of easy disconnects in the fuel line to blow out any blockage.
arod
12-27-2004 13:19:19
Try putting some miniature cows in there...
ha ha. Maybe try filling with water and floating it out? Or use compressed air to blow it out?
Charles Park
12-27-2004 13:28:40
 Re: Getting grass out of gas tank in reply to arod, 12-27-2004 13:19:19
Try filling with water and floating the grass out of the top. May take several tries but I bet you can do it!
Nebraska Cowman
12-27-2004 12:16:44
Mouse nests? Is it dry? if dry air and shaking like allan says might get it after a while. Otherwise you might try lots of water. It ain't gonna be fun.
Allan in NE
12-27-2004 12:14:08
John,
Tank is empty right? Put your air nozzle in there to move things around a little, then shake some more.
You oughta be able to work it all out.
Allan
