460 Power Steering Power Steering Pump?
Dann
12-20-2004 03:39:02
Got a Farmall 460 gas at a auction the power steering dose not work any ideas? Where can I get a rebuild kit for the pump?Thanks
Aces
12-20-2004 08:06:03
 Re: 460 Power Steering Power Steering Pump? in reply to Dann, 12-20-2004 03:39:02
Dann maybe it is not the pump the valve is up front the bolster housing and if the steering shaft is tight some how so the shaft going into the the housing can not in and out a little so the valve can not open and close the power steering will not work the u joint at the housing has a fine spline to mach the shaft that is where it should slide if that it tight or pined then the shaft clear to the steering wheel must move. so check that first.
El Toro
12-20-2004 04:04:10
Try webertractorworks.com and your local IH dealer
may have kits too. Hal
