rear frame
mikefmny
12-19-2004 04:26:30
I have a 350U in our barn that came with some property we bought,seems the inner axle bearing let go and it punched a hole through the bottom of the case,A welder friend of mine says it can be pinned and welded. I'm thinking it's shot and should sell for parts. any thoughts?????
RustyFarmall
12-19-2004 04:36:10
 Re: rear frame in reply to mikefmny, 12-19-2004 04:26:30
There a quite a few Farmall M tractors that suffered the same type of bearing failure, resulting in a hole in the bottom of the case. The bearing was replaced, the hole patched up, and most of these Ms are still working. Listen to your welder friend.
