delco generator conversion to produce 12 volts
EddyJ
11-27-2004 14:42:16
I have a delco Generator off a SW4 ( same as a H ). Delco Number 1100501 . My source for generator parts has a set of coils to convert this generator to produce 12 volts. Has anyone done this?
Is there any problems to encounter other than the coil resistor, bulbs Ect....? What about the adjustment of the 3rd brush?
Trying to keep the original look with more voltage.
Thanks for your input on this
ED
Barry miller
11-28-2004 15:34:21
 Re: delco generator conversion to produce 12 volts in reply to EddyJ, 11-27-2004 14:42:16
I have done this an everything worked fine. I replaced the armatur and set the third brush to put out 12v have had no problems yet.
