lock washer, thick washer or none H head
Jimmie
11-26-2004 17:51:54
rebuilding 49 H motor. When I took it apart the head bolts had thick washers under 4 of them lock washers under 4 and the rest had nothing. Can somebody please tell me what goes under under the nuts or is this correct? Thank You, Jimmie
Aces
11-27-2004 10:41:54
 Re: lock washer, thick washer or none H head in reply to Jimmie, 11-26-2004 17:51:54
Jimmie I think if you look close at the top of the head to blot holes will look like they have a sleeve for the head bolt they need the flat washer.
Nebraska Cowman
11-27-2004 02:47:51
the lock washers do not belong. i can't remember wich bolts get the thick washers
Jimmie
11-27-2004 18:09:51
 Re: Thank You in reply to Nebraska Cowman, 11-27-2004 02:47:51
Many Thanks to both of you. Jimmie
