Water Temp
BVB
11-22-2004 09:30:50
What is the normal water temp for a M farmall.
gusc
11-22-2004 19:13:32
 Re: Water Temp in reply to BVB, 11-22-2004 09:30:50
My Super M manual says it should run at the bottom of the "Normal" range on the IHC gage and that the kerosene burners should run in the middle. It doesn't give the actual degrees.
Bob M
11-22-2004 16:17:50
It depends on weather and load. Assuming a 150 deg thermostat is installed, in cold weather and with a light load it'll struggle to reach even 100. However in warm weather and under heavy load you can safely run to 220 or so if you use 50-50 antifreeze and have a pressure cap on the radiator.
Mine seem to run best between about 170 - 200. But like the NB Cowman I gotta use winterfronts to cover the entire grille to get 'em up to this temperature when the weather is below freezing.
Nebraska Cowman
11-22-2004 15:32:27
"normal" on a lot of old Ms is "cold as ice" cuz someone took the thermostat out or it is stuck open. I always cover my radiator with a dogfeed sack during the winter.
