Farmall A Generator Hookup
Bob Landers
11-17-2004 08:48:36
Almost finished restoring my 46 "A". Many thanks for the great advice from you guys! Bought a new 6V generator and can't figure out where the BAT terinal is located. Is it on the generator housing? The generator only has two terminals--the F and GEN>
gusc
11-18-2004 13:02:19
 Re: Farmall A Generator Hookup in reply to Bob Landers, 11-17-2004 08:48:36
Gen and A (Armature) are the same.
Bob M
11-17-2004 09:14:25
Bob - Apparently what's ordinarily the "A" terminal on your generator is labelled "GEN".
So connect you generator's GEN terminal to the regulator "G" (or "GEN") terminal.
Punch below for a diagram. However keep in mind the difference in terminal designation on your paricular generator!
