1st gear speeds?
Mopower
11-11-2004 13:10:09
What are the approximate 1st gear speeds on the model A, C, H, and M? (Regular, not creeper option.)
Harold H
11-11-2004 14:32:56
 Re: 1st gear speeds? in reply to Mopower, 11-11-2004 13:10:09
A 2.32, C 2.46, H 2.59, M 2.67
Paul from MN
11-12-2004 12:53:43
 Re: 1st gear speeds? in reply to Harold H, 11-11-2004 14:32:56
Harold, where did you get your numbers. I have slightly different ones from the Nebraska tests.
The A, H, and M were all tested in 1939.
A 2.25, H 2.63, M 2.63
The C was tested in 1951
C 2.38
Not a big deal and I have no idea who has the right numbers, just curious as to the different sources.
Paul
Harold H
11-12-2004 13:19:56
 Re: 1st gear speeds? in reply to Paul from MN, 11-12-2004 12:53:43
Mine came from the specs in the 1952 "Tractor Field Book". The specs were furnished by IHC. Different tire sizes might be the difference and gearing might have been changed in some instances since 1939. Since I don't know of a particular gear change, I guess for the tire sizes. On a simular note, tractor weights are shown as different on different years of spec sheets. Same tractors with same equipment listed as standard, but different weights published. I have most of the "Field Books" from 1941 to 1954.
Harold H
Harold H
11-13-2004 04:52:23
 Re: 1st gear speeds? in reply to Harold H, 11-12-2004 13:19:56
Paul,
Another reason for the slight differences, I believe the Nebraska Test speeds are actual observed speeds whereas the IHC published spec speeds are calculated speeds. Tire sizes and different tread heights make the speeds vary both directions from the calculated spec speeds.
Harold H
