I need a wiring diagram!
Galen
10-12-2004 07:45:20
My 59 460 has old wires hanging from when it was a diesel, and most of the wires that are being used are cracked and need replaced. The tractor has also been converted to alternator. Anyone have any ideas? My manual does not show a diagram.
Thanks -
Galen
Phil Auten (TX)
10-12-2004 10:30:44
 Re: I need a wiring diagram! in reply to Galen, 10-12-2004 07:45:20
Check out Duey Schutter's website. He's got diagrams for most combinations of 6V and 12V wiring. They are generic, but will work just fine since your wiring is no longer factory.
Phil
Paul in Mich
10-12-2004 09:45:05
Galen, your nearest case NH dealer should have wiring diagrams for a 460 on file in their computer system. The parts dept should be able tp pull it up, and make a hard copy for you. I"ve gotton nearly any diagram, parts diagram, or assembly blow-up that I have asked for. With a little Schmoozing, your parts man should be happy to help you.
