Farmall H throttle linkage adjustment??
John in Ct.
10-10-2004 06:15:29
What is the correct way to adjust the throttle linkage on a Farmall H. The part I want to adjust are the 2 springs, 2 nut part of the linkage. I am replacing the 2 springs and block part. I know how to adjust the governor. Thanks!!!
The Red
10-10-2004 10:23:26
 Re: Farmall H throttle linkage adjustment?? in reply to John in Ct., 10-10-2004 06:15:29
John I initially set that linkage with about 1/4 inch of that threaded throttle rod sticking out beyond the double nuts. I then check how the engine RPM is at idle and full speed throttle lever positions and adjust from there. The adjustment can vary widely between different Hs and Ms from my experience.
John in Ct
10-10-2004 18:39:41
 Re: Farmall H throttle linkage adjustment?? in reply to The Red, 10-10-2004 10:23:26
Thanks!!
