100 Hydraulic Question
Paul A.
09-28-2004 04:54:42
Hi, I had to replace the hydraulic pump seal on my 100. A local dealer told me to use 30wt non-detergent oil in it, but someone else told me no, to use HyTran. Which should I use?? Also, how full should I fill it - do I need to leave "air room" in the reservoir, I can not see anywhere that it could be vented. Thanks, Paul.
CNKS
09-28-2004 18:36:59
 Re: 100 Hydraulic Question in reply to Paul A., 09-28-2004 04:54:42
Hugh is correct, the dealer is wrong, in particular about the weight -- if you use motor oil, use 10W. But, you have no reason to.
Hugh Mackay
09-28-2004 11:15:50
Paul: Farmall 100, use hy tran and fill to the filler hole with rockshafts both in rear position.
