Cam bearings on w-4 or H
Bob Quale
09-19-2004 14:23:51
How do you check and replace the cam bearings on a W4 or H?
You guys have me nervus about my oil pressure, and the cam bearings are the only thing I didn't change. I had an old IH guy tell me the cam bearings didn't usally wear. Maybe I was told wrong? I'm going to check the pump first of course.
Thanks For the help Bob
El Toro
09-19-2004 15:25:50
 Re: Cam bearings on w-4 or H in reply to Bob Quale, 09-19-2004 14:23:51
Hi Bob, Your machine shop should've recommended
new cam bearings. Did you have that block cooked?
They usually recommend new bearings when this is done and a new cam too if the lobes are worn. I always use SAE30 oil in the tractors when used hard in the field, such as plowing or discing. I hate tearing down the engine twice.
My neighbor was watching me pulling my gas tank on a car to replace the fuel pump. He said I wouldn't change that pump. I replied you're not doing the work, I'm the one that would have to pull that tank again and I don't like doing it twice. Good Luck, Hal
Bob Quale
09-19-2004 15:46:12
 Re: Cam bearings on w-4 or H in reply to El Toro, 09-19-2004 15:25:50
I did not have the block cooked, it was clean inside, no gunk. The IH guy said the cam bearings usually don't go and they seamed to be tight. I also was over budget and that played a big part. The cam it self looked good and a replacment is not available. I am going to check the oil pump well and hope I find the problem there.
Thanks Bob
