300 Utility
Glenn in Tx
09-11-2004 09:19:02
Would like to know if all you have to do two change from Positive ground to negative ground is to switch wires around .
CNKS
09-11-2004 09:59:38
 Re: 300 Utility in reply to Glenn in Tx, 09-11-2004 09:19:02
Unless you switched to an alternator, that will serve no purpose. In fact, your regulator will burn out sooner. If you insist, you have to reverse the leads on the ammeter and repolarize the generator. The link is some of Bob M's wiring diagrams.
