Light Switch Decal
GooseCreek Farm
09-09-2004 13:24:12
The decal package we purchased came with two decals for the light switch. One shows "LH D B" and the other shows "O D B". We would appreciate some help selecting the correct decal to install to the light switch box. The tractor is a 1947 Farmall "M" and it still has the original wiring which is 6 volt, with a positive ground. Thanks for your help in advance.
CNKS
09-09-2004 18:00:32
 Re: Light Switch Decal in reply to GooseCreek Farms, 09-09-2004 13:24:12
47 is probably 4 position, meaning you have a cutout relay instead of a voltage regulator.
GooseCreek Farms
09-09-2004 16:46:14
Thanks for both your response. I believe we have a 3 position switch, which I will check tomorrow when I install the decal.
SGT K
09-09-2004 16:17:50
The L H D B switch is for the four positions on the switch, which are, low charge (for charging the battery while working in the field), high charge (for barn yard and low RPM work), dim and bright. If you have a four position switch you should feel each click.
Now, if you already knew all of this and you're asking which switch is correct for your tractor, I'm not sure. My 48 H has the four position switch.
Good Luck
Paul
Dick Davis
09-10-2004 02:29:27
 Re: Light Switch Decal in reply to SGT K, 09-09-2004 16:17:50
Paul, I agree with your post. But I always thought the B should have been an A.
A standing for: A Little Less Dim. My nickel Dick Davis
The Red
09-09-2004 14:25:16
You have either a 3 position or 4 position switch. That will determine which decal to use.
