300 Utility
Glenn G
08-25-2004 15:05:39
I have a 300 that I would like to convert from
9 volt to 12 volt can some one help?
Ibby
08-26-2004 04:32:05
 Re: 300 Utility in reply to Glenn G, 08-25-2004 15:05:39
The very easiest way is to take a Chevy alternator with a built in regulator to a good automotive rebuilder. For around $50, he'll rebuild it and convert it to a 1 wire system. Supposed to start charging at lower rpms and be more dust and vibration resistance, too. Hook the one wire up to your ammeter, change your coil to a 12 volt coil (You can get original style coils in 12 volt, if you want, or just use an automotive universal 12 volt coil).
Ken in Iowa
08-25-2004 18:50:46
I converted mine back in the 60s by using a 12V generator and regulator made for a 350. It bolted right up. You will need a ballast resistor to cut the voltage back to about 6V that feeds the coil. You should be able to find a resistor and mounting bracket at an auto supply such as NAPA. Mine is mounted at the coil. Resistors were used on older cars. Your 6V starter will work just fine. Don't forget to change all of the light bulbs. Good luck, Ken
