Order Farmall Cub Parts Online
Cub loboy still showing discharge?
Jaybird
08-10-2004 19:49:05
I have a cub loboy that still shows discharge on the amp.gauge.I have replaced the Gen.(New)the Reg.(New)the Bat.(New) and polerized the Reg.The only thing that hasen't been replaced is the Amp.gauge.If the gauge shows discharge when running,can the gauge still be bad? I'm out of ideas!
Jaybird
08-12-2004 09:17:55
 Re: Cub loboy still showing discharge? in reply to Jaybird, 08-10-2004 19:49:05
thanks for the info. I will check it out
Kenneth
08-10-2004 20:28:21
My first guess would be the amp guage may be hooked up backwards. If you switched to neg. ground instead of original pos. ground you will have to reverse the wires on the amp guage.
Jim Becker
08-10-2004 20:13:02
Which way does the ammeter move when you just turn the switch on? Maybe the ammeter is hooked up backwards.
steve(ill)
08-10-2004 19:54:53
i would guess the voltage regulator has a bad ground. clean the paint or rust at the mounting screws. to test the generator, remove the "A" and "F" wires. ground the F to the frame. start tractor and measure the voltage across the "A" and "F". you should have about 20 volts without the regulator. if this works, the reg is bad or no ground.
