706 Bad Engine???
Kyle
08-10-2004 16:47:04
i seen a 706 for sale says bad engine no price in the ad i know it is a diesel also....What is it worth???? what does it cost to rebuild one???
caseyc
08-11-2004 07:31:46
 Re: 706 Bad Engine??? in reply to Kyle, 08-10-2004 16:47:04
are you in south dakota? theres one here forsale w/ a bad engine. is it a 690 prefix? if it's the same one i already looked at it.
kyle
08-11-2004 07:39:00
 Re: 706 Bad Engine??? in reply to caseyc, 08-11-2004 07:31:46
Yes i am from south dakota i seen it in the argus leader....i noticed it had been there a while was wondering if it could be had for a good price....
caseyc
08-11-2004 09:01:10
 Re: 706 Bad Engine??? in reply to kyle , 08-11-2004 07:39:00
that's the one! i'm in toronto and the tractor is in white. the guy is very firm on $2000. he says the head is the problem. it's a 282 glowplug diesel. has a cab and fast hitch converted to a three point, no t/a. it is VERY rough! to me it's only a $500 project tractor, maybe $1000 on a good day but that's it. the same guy also has a 806 diesel w/ a cab and fast hitch and a t/a. also $2000. a better buy. was parked because the motor was getting tired, but still ran when parked(quite a few years ago). it also is in rough shape but far better than the 706. hope this helps.
hagan
08-11-2004 11:23:38
 Re: 706 Bad Engine??? in reply to caseyc, 08-11-2004 09:01:10
I have a 715 diesel combine and 15 years ago the head cracked (it has the exact same head) and lo and behoe after I received 3 repaired heads one of them even was patched with body putty where cavitation occured really badly I finally got a new head. It cost nearly $1400 by the time I was done with the head. Do you put on a new head with old rings? I did and re rung the engine the next summer and replaced the bearings. Beleive you me you will spend most all of $2000 and still not have what you expect.
Maybe it was my luck but I know that there were more parts available 15 yrs ago and repairs do go up. Maybe it was my luck with the salvage yards I dealt with but I wonder after what I have seen at times.
Just my 2 cents worth--
caseyc
08-11-2004 13:17:53
 Re: 706 Bad Engine??? in reply to hagan, 08-11-2004 11:23:38
sorry for not making myself alittle more clear....i would only pay $500 for the tractor in the shape it's sitting, maybe $1000 if i was feeling generous. this tractor would take countless hours and money to make decent and useable.
caseyc
08-11-2004 09:52:42
forgot to say that i know where there is a nice 706 forsale. under $5000. i'll unmask my e-mail if your interested.
Allan in NE
08-11-2004 05:27:41
Kyle,
I'd be a little concerned about the crank in the thing. If it needs replaced, you might as well figure that you need an engine and what's that gonna cost? $10K? $12K?
There's probably a reason it is for sale with a bad engine.
Allan
Leland
08-10-2004 18:44:28
Look on this site under engine kits then find out what they charge for head job in your area
