Low-Low Speed
Ted
08-06-2004 05:28:06
I have the original owners manual for my "H". In it on page 97 it writes about the special attachments (accessories) available for the tractor. The one I never knew about was a Low-Low Speed. It writes " This attachment provides special low gear for Farmall-H Tractors when used with Harvester-Threshers in heavy conditions. Does anyone have experience with this? Does it effect reverse? Does anyone ever see this option forsale anywhere? Was this option available for "M" tractors?
Jed
08-06-2004 11:10:00
 Re: Low-Low Speed in reply to Ted, 08-06-2004 05:28:06
I have one in a 51 M. It doubles the pulling HP when you are in that gear. Yes, reverse is also slower. I have seen several in M's and H's.
About 1 in 20.
Dave W V
08-06-2004 06:13:15
Gives around 1.5 mile per hour speed on H & M at governed RPM depending on tire size used. Reverse is slowed down also.I agree with CNKS,
getting hard to find.
CNKS
08-06-2004 05:44:49
Available for H,M,A,B, perhaps C and others, I don't know. The H and M system is an actual gear, I believe the A and B system uses the PTO. Not many were made, fewer still exist, good luck finding one. I don't believe it affects reverse, could be wrong.
Red Dave
08-06-2004 17:35:36
 Re: Low-Low Speed in reply to CNKS, 08-06-2004 05:44:49
I've heard of the creeper for the C/Super C, but I never heard of a creeper for the A & B. Do you know where I can get any more info on it?
CNKS
08-06-2004 18:34:58
 Re: Low-Low Speed in reply to Red Dave, 08-06-2004 17:35:36
I don't know. I believe Hugh McKay, or someone explained the A,B, Super A one. My Super A parts manual shows a hydraulic motor and some sort of a chain drive. I believe it runs off the pto. I have never seen one. I looked in my C parts book and operators manual, and found no mention of one. Is it hydraulic, or a gear like in the H/M?
