calcium cloride mix
tractor dan
07-23-2004 18:24:21
i want reload some tractor tires with calcium cloride but the new bags of cloride dont have the chart on them like the old bags so im not sure how many pounds of cloride to mix up 50 gallons thank you
Alvin NE WI
07-24-2004 18:07:09
 Re: calcium cloride mix in reply to tractor dan, 07-23-2004 18:24:21
for 50 gallons of water use about 200 lbs. of calcium cloride which will be good for a -35 degree day. That is what my book shows.Don't worry about bad things from it IF you have a leak in a tire and repair itsoon, which are good farming practice. If you want to negleck it than pay the piper. I just took my '38 tractor apart with the calcium in it for at least 50 years, yet the rims are good.
Farmer Bob
07-23-2004 22:10:09
Here's come tech info on hydroinflation:
GENERAL FARM TIRE INFORMATION V. HYDROINFLATION
When removing fluid from tubeless tires, be careful not to unseat beads until most of fluid has been pumped from the tire. Consult your tire supplier for information on hydro-inflation equipment such as pumps, compressors, air-water conversion hardware parts, etc. Tire rotated so valve is at bottom with hydro-inflation fluid being removed. NOTES: Tables are based on using type 1 calcium chloride (77% CaCl2). If type 2 concentrated calcium chloride (94% CaCl2) is used, reduce specified “Lbs. CaCl2” in tables by 25%. Values shown in tables are approximate and represent 75% fill or “valve level” fill (with valve at top of tire) which is recommended practice. Antifreeze protection levels are shown at top of each table for different solutions. For rear tires mounted on narrower rims, decrease quantities at the rate of 4% for each 1-inch reduction in rim width. For wider rims, increase quantities by 4% for each 1-inch increase in rim width. Tire Size Rim Width WATER 31/2 LB. SOLUTION 5 LB. SOLUTION Solid at +32°F. Slush-free to -12°F. Solid at -52°F. Slush-free to -53°F. Solid at -62°F. Water Gal. Weight Lbs. Water Gal. CaCI2 Lbs. Total Wt. Water Gal. CaCI2 Lbs. Total Wt. DRIVE WHEEL TIRES 8.3-24 7.00 13 108 11 39 131 10 50 133 9.5-16 8.00 12 100 10 35 118 10 50 133 9.5-24 8.00 17 142 15 53 178 14 70 187 9.5-32 8.00 22 183 19 67 225 18 90 240 9.5-36 8.00 25 208 22 77 260 20 100 267 9.5-42 8.00 29 242 25 88 296 23 115 307 11.2-24 10.00 24 200 20 70 237 19 95 253 11.2-28 10.00 27 225 24 84 284 22 110 293 11.2-36 10.00 35 292 30 105 355 28 140 374 11.2-38 10.00 36 300 31 109 368 29 145 387 12.4-24 11.00 30 250 26 91 308 25 125 333 12.4-28 11.00 35 292 30 105 355 28 140 374 12.4-36 11.00 44 367 38 133 450 36 180 480 12.4-38 11.00 46 384 40 140 474 37 185 494 12.4-42 11.00 51 425 44 154 521 41 205 547 12.4-46 12.00 53 442 45 158 533 43 215 573 12.4-54 10.00 58 484 49 172 581 47 235 627 13.6-24 12.00 38 317 32 112 379 30 150 400 13.6-26 12.00 40 334 35 123 415 33 165 440 13.6-28 12.00 43 359 37 130 439 35 175 467 13.6-38 12.00 57 475 49 172 581 46 230 614 13.6-46 12.00 65 542 55 193 651 52 260 694 13.9-36 12.00 51 425 44 154 521 42 210 560 14.9-24 13.00 47 392 40 140 474 38 190 507 14.9-26 12.00 48 400 41 144 486 39 195 520 14.9-28 13.00 53 442 46 161 545 43 215 574 14.9-30 13.00 57 475 48 168 568 46 230 614 14.9-34 13.00 63 525 54 189 639 51 255 680 14.9-38 12.00 67 559 58 203 687 55 275 734 14.9-46 12.00 80 667 68 238 805 65 325 867 15.5-38 14.00 66 550 56 196 663 53 265 707 16.9-24 15.00 61 509 52 182 616 49 245 654 16.9-26 15.00 65 542 56 196 663 52 260 694 16.9-28 15.00 69 575 59 207 699 56 280 747 16.9-30 15.00 73 609 63 221 746 59 295 787 16.9-34 15.00 82 684 70 245 829 66 330 880 16.9-38 15.00 90 751 77 270 912 73 365 974 17.5L-24 15.00 55 459 47 165 557 45 225 600 18.4-16.1 16.00 49 409 42 147 497 39 195 520
Hugh MacKay
07-23-2004 20:26:28
Dan: It's been a long time, but I can remember using the whole bag for a 13.6x38. I think calcium chloride was close to 100 lbs per bag back then.
Anti-freeze could be a good solution in the right area. It would get quite expensive here or at your place in VT. I realize you wouldn't need it quite as strong as for a cooling system, but I think you would have to go at least 35% anti-freeze.
Rock
07-23-2004 18:45:11
Dan,
I put about 2.5 gallons of antifreeze per tire in mine and the rest water and have no problems and dont have to worry about the calcium eating my rims up. If you are in a very cold climate you may have to put more in. Have never used the calcium in mine. Maybe someone else can give you the ratio to put in.
Rock
