Battery ground
Bob
06-30-2004 07:25:41
On a 6vt system on an H is it a + or - system is the + grouned or - grouned, also what oil gos in the HYD. system
rustyfarmall
06-30-2004 09:43:47
 Re: Battery ground in reply to Bob, 06-30-2004 07:25:41
Hydraulic system calls for 30 wt. non-detergent motor oil, lighter weight oil for cold weather operation. You may use hy-tran if you desire.
Red Dave
06-30-2004 07:35:21
From the factory your H would have been a 6 volt, positive ground electrical system.
Over the past 50 - 60 years somebody may have made a lot of changes to the tractor, so proceed cautiously until you figure out what you have there.
