LIVE HYDRAULIC'S ON 400D
BULLDOG
06-29-2004 09:38:12
I HAVE VERY LOW PRESSURE. BARELY LIFTS FAST HITCH WITHOUT IMPLEMENT. I HAVE PUT NEW SEALS IN THE HYD. PUMP WHICH IS MOUNTED JUST BEHIND THE DISTRIBUTOR. THE CASE AND GEARS LOOKED SUPER. I HAVE REPLACED THE SUCTION FILTER IN THE RESERVOIR. I HAVE BLED THE PUMP THROUGH THE PIPE PLUG AT THE TOP AND BY RUNNING THE HITCH UP AND DOWN. USING HY-TRAN. ANY IDEAS HERE GUYS?
Geoff NY
06-30-2004 12:49:29
 Re: LIVE HYDRAULIC'S ON 400D in reply to BULLDOG, 06-29-2004 09:38:12
My parts book shows it at the top of the first valve ( left one if you were in the operator's seat ) Good luck Geoff
Geoff NY
06-29-2004 10:26:33
Did you by any chance reverse the hydraulic lines from the block on the battery box to the piston? Also check the pressure relief valve at the resovoir. Good luck!
BULLDOG
06-29-2004 10:32:25
 Re: Re: LIVE HYDRAULIC'S ON 400D in reply to Geoff NY, 06-29-2004 10:26:33
THANKS GEOFF, WHERE IS THE RELIEF VALVE?
