Flywheel and Pressure plate bolt torque spec
Red Rookie in W
06-25-2004 15:44:55
I split my 240U to free up the rusted clutch. Mice had went through the bottom of the torque tube and had packed the bellhousing with nest material. The combination of urine and humidity rusted the clutch into a mess that looked like it had been lying on the deck of the Titanic. Anyway,I got it cleaned up bit I do not know what to torque the flywheel and pressure plate bolts to. Can anyone help me out.
El Toro
06-27-2004 05:09:26
 Re: Flywheel and Pressure plate bolt torque spec in reply to Red Rookie in Wi, 06-25-2004 15:44:55
Hi Red, Call your local IHC service department
and they can supply those torques. You could probably use the bolt torques from a machinist's
handbook, depending on the size of those bolts.
I would call the dealer to be on the safe side. Even Yesterday's Tractor may be able to supply those torques. Hal
