300U-Voltage to coil?
Gord
06-22-2004 15:09:56
I have a 300U that died suddenly last fall, when I finally got a chance to check it out I found that that sprung steel arm on the points was "broken."
Could it have burnt off? Hard for me to tell, but this tractor has a 12 volt battery, and there is a resistor of some type on the coil bracket. Does anyone know what the resistance through this resistor should be?
Also, how many ohms should I read across my coil?
Any help would be greatly appreciated.
Ibby
06-23-2004 02:46:02
 Re: 300U-Voltage to coil? in reply to Gord, 06-22-2004 15:09:56
When I converted my 350U to 12 volt, I used a resister as you described, and had nothing but trouble with it. Once I switched to a 12 volt coil, my problems went away. You can use any 12 volt coil, or you can buy OEM style ones that fit the existing bracket.
Gord
06-23-2004 06:48:28
 Re: Re: 300U-Voltage to coil? in reply to Ibby, 06-23-2004 02:46:02
Thanks Ibby, I think I will try a new coil to see if that helps.
Gord
