Check M hydraulic level ?
Anthony
06-21-2004 07:11:10
How do I check the hydraulic oil level in my M? I pulled the plug on top, expecting a dipstick, but there ain't one there. Am I looking in the wrong spot? If the dipstick is gone, is there any other way to guage when full? Also, I'd like to drain it, as I have no idea how long since it's been changed. Where is the correct drain, and how many gallons to refill? Thanks for the help y'all.
Hermit
06-21-2004 10:41:56
 Re: Check M hydraulic level ? in reply to Anthony, 06-21-2004 07:11:10
You're probably looking in the right spot but a lot of those dipsticks have disappeared off the cap over the years, maybe into the reservoir. The top of the oil level is approx. 9 inches below the top of the filler neck (info in archives). You can make yourself a dipstick out of an old car dipstick bent and marked to the right length. There is a drain plug on the bottom of the lift-all unit. The reservior holds 6 quarts.
