Amp Gauge 1950 Farmal H
Ross L
06-08-2004 14:01:31
Hey Guys,
Kind of a stupid question. I have a 1950 H that has been converted to 12 volt. Would the amp gauge be different from the six volt? I want to use original style gauges on my restoration. Thanks. Ross
gene b
06-12-2004 04:06:23
 Re: Amp Gauge 1950 Farmal H in reply to Ross L, 06-08-2004 14:01:31
You say you are restoring it and want to keep the guage then why are you going to 12v when they have been starting and running with 6v for 60+yrs.
Ross L
06-14-2004 06:45:56
 Re: Re: Amp Gauge 1950 Farmal H in reply to gene b, 06-12-2004 04:06:23
The tractor had already been converted to 12V when I bought it. I guess it all depends how you look upon a restoration. I didn't plan to restore the tractor to the exact way it left the factory, if that is possible. I rebuilt the engine and repainted the tractor. Of course the paint I used was better than was available when the tractor was built, so I guess it would not be a true restoration anyway. I was hoping to use gauges with the IH logo instead of a generic brand. The 12V system suits my needs better.
CNKS
06-08-2004 18:37:43
If you change to a negative ground alternator, reverse the leads on the ammeter so it will show a positive charge.
Pete
06-08-2004 14:21:42
There are no stupid questions and yes your
amp gauge will work on 6 or 12 volts
