TA in 766
Phil
06-06-2004 19:03:39
How can I tell for sure if the TA is slipping or the clutch is slipping? Would changing the pump help it any? Thank-you, Phil
RB
06-07-2004 08:43:51
 Re: TA in 766 in reply to Phil, 06-06-2004 19:03:39
Drive the tractor in HI 1st wide open throttle TA lever forward. Load the tractor by applying the brakes, note whether it slips. Shift the TA and note again what is happening. If tractor stops completely it is the TA out on the low side. If it still slips it is the clutch. A good low side TA cannot slip or stop, it is a mechanical lockup by a sprag.
Allan
06-07-2004 03:07:46
Hi Phil,
If the two speeds do in fact work, with the stick forward and you feel 'er slip, the problem is more than likely in the main clutch.
If it slips with the stick back, problem is probably in the T/A or it's clutch.
There are lots and lots of things that need to be checked before you get down to a pump replacement, in my opinion.
Nice tractors those 766s,
Allan
