300-660 pto
lee
05-20-2004 19:50:27
Are the planetary pto units all interchangable Also are the newer clutch style units compatable thank you Lee
Jim J
05-21-2004 07:14:37
 Re: 300-660 pto in reply to lee, 05-20-2004 19:50:27
The will fit. I have interchanging them for years. The early PTO's have a different rear cover than the late PTO's, And of course you will have to have the spacer for the 300 - 460.
Randy in NE
05-21-2004 04:32:42
I looked up a couple of the part numbers for both the 300/350 and the 560/660. The "Carrier, planet and rear shaft", "Shaft, drive, w/ring gear", and the "Cage, drive shaft bearing" all have the same part numbers. It appears that there is a high probability that they are interchangable. Side-by-side comparison would still be a more reliable method.
