ih 444
jm
05-15-2004 19:43:40
Does anyone have any info on overhauling a 444 gas engine? I am starting to get a fair amount of blow by. Are there kits available? any info would be appreciated
Ben in KY
05-17-2004 06:02:31
 Re: ih 444 in reply to jm, 05-15-2004 19:43:40
The C153 Gas engine is not sleeved, must be rebored. Parts are available but not common.
parts man
05-16-2004 15:40:23
jm, the first thing you need to know is whether you have the c-153 engine, or the british bc-144. It will be marked on the engine block on a flat machined surface, along with the engine serial number. Engine kits will be availlable from your CASE-IH dealer, or after-market sources for either engine.
jm
05-16-2004 19:53:04
 Re: Re: ih 444 in reply to parts man, 05-16-2004 15:40:23
thanks for the info, i will check on the motor type. just got the tractor, knew the motor wasn't perfect but couldn't pass it up.
