450 farmall power steering help please
tom murphy
05-07-2004 19:58:58
Hello, My 450 farmall power steering box is leaking all down the motor. can these have new seals put in them or is it better to just find another one or is that imposible? what would the best solution be? Thanks..Tom
Hoppy
05-10-2004 06:01:49
 Re: 450 farmall power steering help please in reply to tom murphy, 05-07-2004 19:58:58
Just got done redoing a 350 Behlen steering unit. Replaced the needle bearings, O rings, and gaskets. Oil was leaking past the O rings on the output shaft. Should know by the end of the week if I was successfull. Got my parts from IH.
R. Anderson
05-08-2004 10:49:04
Tom, I just went through the same thing with my 450. My tractor has the Behlyns power steering motor on it. I took mine completly apart to replace all the seals in it. Once I got it apart I found out that the shaft, that faces the aft of the tractor, had a groove worn in it where the seal rides. I took the shaft to the machine shop to see if they could build it up and turn it down, but they said that with a long shaft like that and the groove in the middle of the the shaft, that it would warp the shaft. I ended up getting a used, complete motor, from a salvage yard and installed instead. I am going to take my old shaft and build it up with some J.B weld and turn it down and see if it works, if not, oh well, I am out nothing for trying.
