mcormick w 4 ele ?
arne
05-06-2004 14:50:34
6 volt sys. is it posi or neg. ground?
Wayne Swenson
05-06-2004 21:02:40
 Re: mcormick w 4 ele ? in reply to arne, 05-06-2004 14:50:34
Originally was Positive ground.
Farmallkid
05-06-2004 14:58:55
Pos. We had my m hooked up to neg,didnt start worth a crap. Then we hooked it up to pos, starts a bit better.
49 Cubber!
05-07-2004 12:30:44
 Re: Re: mcormick w 4 ele ? in reply to Farmallkid, 05-06-2004 14:58:55
I seriously dought that your starting problem had anything to do with which way the battry was hooked up.The only thing that would matter is the charging.Most likely when you changed the battery around,you got a better contact on the battery post.
Farmallkid
05-07-2004 13:47:47
 Re: Re: Re: mcormick w 4 ele ? in reply to 49 Cubber!, 05-07-2004 12:30:44
Ya i just thought about it some more, youre right. I should get some new battery cables, that would help a bit.
49 Cubber!
05-07-2004 13:59:13
 Re: Re: Re: Re: mcormick w 4 ele ? in reply to Farmallkid, 05-07-2004 13:47:47
Even if your on 12 volt,get the biggest cables you can,0 or 1 gauge if you can find it works well for me.Some use welding cable.
