Need torque specs for Farmall A cylinder head.
Tom Williams II
05-05-2004 16:15:33
Hi again. We need to know how tight to torque the cylinder head bolts on our 46 Farmall A. We are redoing a lot of it so it can last us and our offspring a long time we hope.
Any help you can give will, as always, be greatly appreciated.
Thanks to you all for making this such a nice place.
Tom
Randy in NE
05-05-2004 18:18:41
 Re: Need torque specs for Farmall A cylinder head. in reply to Tom Williams III, 05-05-2004 16:15:33
The head bolts get torqued to 80 ft-lbs. Work from the center out towards both ends at the same time. You may start at 40 ft-lbs, work your way through all of the bolts, and then increment in 10 lb increments. After you get it all together you will need to run the engine long enough to get it up to operating temperature and then re-torque the head bolts. This means pulling the rocker arm off, torqueing the head bolts, replacing the rocker arms, and then setting the valves again.
Tom Williams III
05-06-2004 07:53:07
 Re: Re: Need torque specs for Farmall A cylinder h in reply to Randy in NE, 05-05-2004 18:18:41
Thanks, Randy. You guys always seem to come through. Hope I can be of help to you sometime too.
Tom
BIG JOHN
05-05-2004 18:10:56
Go to - www.weberstractorworks.com - you will find all that you want to know about spec's.
GOOD LUCK WITH YOUR WORK
Tom Williams III
05-06-2004 07:54:28
 Re: Re: Need torque specs for Farmall A cylinder h in reply to BIG JOHN, 05-05-2004 18:10:56
Thanks, Big John. Went to weberstractorworks.com and found a lot of great information.
Hope I can return the favor sometime.
Tom
