farmall help please
Tom
04-30-2004 21:17:25
Hello, I am new here and just got a farmall from a guy for $300.00..he had no idea what year it is.the tag on the side has all the lettering wore off except one set of numbers.they are 9491 s..he said it is a international farmall 450..the side of the tin has mccormic international farmall on it.how can i find out what year it is and if it really is a 450?any help would be appriciated..Thasnks..Tom
Tom Murphy
05-01-2004 11:27:49
 Re: farmall help please in reply to Tom, 04-30-2004 21:17:25
Thanks for the info guys..I found the side cover emblem and it is a 450..looks like the casting numbers i can find end with a G..what year would that be? what years was the farmall 450 in production? Thanks..Tom
Aaron
05-02-2004 10:45:03
 Re: Re: farmall help please in reply to Tom Murphy, 05-01-2004 11:27:49
Is it an international or a farmall? They were both made by IH but the farmall was a rowcrop version and the international was a utility version. If it is an international it will have a wide front and be fairly short. If it is a farmall it can have a wide or narrow front and will be about 6 feet to the top of the hood.
CNKS
05-01-2004 19:01:01
450 was built from 1956-58. There seems to be a conflict as G is a code for 1961. If the SN is 9xxx, you may have a 460 utility. But this is a low profile tractor with a wide front end. Does it have 4 cylinders or 6? Are you sure the casting codes (look at more than one) read month*day*G?
Wardner
05-01-2004 10:16:55
Look for casting dates. There should be a minimum of six on your tractor.
They should be similar to the following:
*12-3-A* = 3 December 1955
*6-30-B* = 30 June 1956
*10-2-C* = 2 October 1957
*3-14-D* = 14 March 1958
Ibby
05-01-2004 04:50:27
A Farmall 450 is a pretty good sized tractor. It'll be almost 6' to the top of the hood. I guess the first thing I'd do is clean the crud off the engine behind the oil filter, just above the inspection plate. Look for a number in the cast that starts with C-xxx. On the 450, It'll read C-281 (I just went and double checked mine). That doesn't preclude the fact that someone might have swapped out the engine (If in fact any other engine would fit in a 450, or a 450 engine would fit in anything else - I don't know) I do know my 350 has a 300 engine, so it's possible that a 400 engine would fit in a 450. It's a place to start anyway.
Gary_N_WV
05-01-2004 04:39:39
Tom,
Welcome aboard ! You might start by going to the tractor photos link at the left and matching your tractor to one of them to give you an idea what you have.
After you have narrowed down to what you have, someone here can give you a little help.
Gary
