grease seals Farmall A
Mike
03-30-2004 21:32:53
I need to replace the grease seals on the front wheel axels. They look to be very old and maybe original. I have not been sucessful in removing them as they are stuck on the shafts real tight and I don't want to damage them until I find out if they are replaceable. Any Ideas on getting them off or a good source for new ones would be greatly appreciated. Thanks
Haas
03-31-2004 05:11:29
 Re: grease seals Farmall A in reply to Mike, 03-30-2004 21:32:53
Wheel bearing kits are readily available and they include the grease seals. You can also buy the parts individually, but if you buy more than one or two parts, might as well buy the kit and replace everything. Try cngco.com
Red Dave
03-31-2004 05:11:06
The last ones I did came as a kit with the seals and bearings together.
Check with a Case/IH dealer. I got mine from Carter&Gruenwald 608-455-2411
