Engine serial number and tractor serial number
Wesley M. Store
03-29-2004 05:41:36
I am working on my dad's 1962 cub. We still use the little tractor for our garden work, however, the fan has frozen up and will not turn. Where do I find the engine serial number or can I use the tractor serial number to order the part I found on Yesterday's tractor web page? Can I also buy a generator brace and a water neck (which connects to the block for the generator brace) also. I would like to repair it all at one time if I can. Any help will be appreciated.
Jim Becker
03-29-2004 19:03:52
 Re: Engine serial number and tractor serial number in reply to Wesley M. Storey, 03-29-2004 05:41:36
The Parts Catalog contradicts itself on whether the change was at the stated engine number or serial number. Either way, a '62 model (if that is what it really is) should have the later style with the larger generator drive pulley.
As John pointed out, newer replacement hubs have sealed bearings.
