IH 574
Brad in VA
03-22-2004 11:42:21
I just bought a IH 574 at a auction in Clover VA on sat. Didnt really want it but was bidding and ended up with it. The tractor is a diesel. I had some questions about it. 1) There is a leaver on the right side of the driver down close to the floor that has a sticker around it the shows the tractor going forward and backwards. When it is in the middle the tractor moves when you let out on the clutch. If you pull it backwards it growls and pulls on the motor???? What is this????
2) Are there any problems with these that need attention??? The guy who had it before didnt like much greese. On the three point anyways. The front looked good though.
3) It has 13.6/36 tires on the rear, from what I can find out it should of had 28" tires on the rear. It was tobacco country down there, is that why???
4) Does anyone know of a good parts place for them?? I need the battery door and some knobs for the levers, a grill and the schroud around the grill.
5) How do the do in the field??? We do alot of hay and raise cattle. I wanted it for raking and tedding. Will it handle the round baler or does it lack that kind of power (4'x4' bales)
6) This one is hard to get and keep in first. It goes in ok but you have to hold the handle up there untill you let out on the clutch or it will slip out of gear.
Any thoughts will be appericated.
Farmaller
03-22-2004 13:05:52
 Re: IH 574 in reply to Brad in VA, 03-22-2004 11:42:21
That lever is your hydraulic remote . I always used my foot to raise or lower it. Your linkage is wore and needs adjusting to keep it in first, might need a spring.Parts are hard to find, I painted mine and couldn't get decals. Might try bates.corp. for parts
Wayne M Kittler
03-22-2004 17:14:56
 Re: Re: IH 574 in reply to Farmaller, 03-22-2004 13:05:52
You have a 574 rowcrop. An IH dealer should be able to sell you the parts you need. My 574 is not a good pulling tractor. The H walks away from it. What it is good for is hydraulics and loader work.
