IHC Plows
John in NE
03-15-2004 09:56:51
What is the difference between the "Little Wonder" and "Little Genius" plows? John.
Dan
03-16-2004 19:32:12
 Re: IHC Plows in reply to John in NE, 03-15-2004 09:56:51
When dad was collecting old internationals, he always called the Little Wonder, the Little Wanderer. He use to do some antique plowing contests.
Hugh MacKay
03-15-2004 14:49:51
John: A Little Wonder plow may or may not have a tail wheel. The tail wheel is fixed, if no tail wheel it will have a long land side on the back moldboard.
The Little Genius will have a tail wheel that not only pivots but also lifts the rear of the plow. There will be a linkage running from tail wheel along the top of the plow and hooked into and activated by the rockshaft of the left front wheel. This causes the plow to lift and lower front end first, making much neater headlands.
The Little Genius was the delux plow and Little Wonder economy.
Farm w/Junk
03-15-2004 12:23:21
Hi the little wonder plow had a fixed tail wheel, meaning that it did not pivot anywhere, the little genius has a tail wheel that follows where the plow goes, pivots. Hope this helps. Send me a pic, I can probably tell you what ya got. I have 6 little genius plows here now. Good luck. Matt
John in NE
03-15-2004 13:00:41
 Re: Re: IHC Plows in reply to Farm w/Junk, 03-15-2004 12:23:21
I,m going to get it this weekend.I guess I'll know what it is when I get there.It does have the tailwheel that pivots,so it must be a Little Genius. John
Nebraska Cowman
03-15-2004 10:18:15
I don't pretend to know nothin' about anything but think thar the Wonder was a lighter cheaper plow. Not sure but I don't think the Wonder had a tail wheel.
John in NE
03-15-2004 10:42:35
 Re: Re: IHC Plows in reply to Nebraska Cowman, 03-15-2004 10:18:15
Thanks,I got the plow bought on ebay,and I saw manuals for each on ebay now and I not sure which one I need.John
oleblu
03-15-2004 17:20:47
 Re: Re: Re: IHC Plows in reply to John in NE, 03-15-2004 10:42:35
Let me know what manual you need and I might be able to help you out. Jim Thurnau
