Remove Belt Pulley Housing on SMTA?
Gene
03-06-2004 19:30:29
How do you remove the belt pulley housing on a SMTA?
Andy Martin
03-07-2004 08:10:48
 Re: Remove Belt Pulley Housing on SMTA? in reply to Gene, 03-06-2004 19:30:29
There are lineup pins which fit tight.
They can be stuck and make it hard to get the castings apart.
Use plenty of penetrating oil and time.
Dan
03-06-2004 19:46:29
Just take the bolts out around it and pick it up. I took mine off a couple years ago to fix ta and I had the gas tank off anyway. I think you could take it off without removing gas tank. It just has to lift up a bit.
