584 trans fluid
Jeff Flaharty
03-02-2004 12:45:45
I was wondering how to check trans fluid level. Do I allow the engine to run or not? Also, is there an easier place to resupply other than the dipstick tube?
Thanks,
Jeff
Bernard le mécano
03-02-2004 17:15:41
 Re: 584 trans fluid in reply to Jeff Flaharty, 03-02-2004 12:45:45
Hi Jeff, on this tractor, check with engine at 1250 RPM. Add oil by the plug on the top of the hydrolic cover, back of the seat. It's the same with all 54,74,84,85,95,4200,CX series. Also all big Farmhall to. bernard le mécano Québec Canada
RAS
03-02-2004 14:14:58
Check with engine off. Right next to the couplers in the back of the tractor is a fill plug.
