IH 46 Baler
Steve(OR)
03-02-2004 11:32:31
I posted this over on the implement forum and no takers. Anybody here want to try?
Old baler needs help.
1 - Two part drive line broken or twisted on both sides of carrier bearing. Can it be replaced with a one piece line? Did the carrier bearing serve any purpose other than to shorten the presumably more expensive sliding portion of the line? Wouldn't a longer one piece line mean less angle at the PTO? Is a new line going to cost more than the baler is worth?
2 - When the baler was last working 4 years ago it was making curved bales. When I inherited the baler we tried stationary baling to learn a little about it, until the drive line broke (too severe angle - what a learning experience!). The twine could be pulled thru by hand when the baler wasn't running but as soon as it was turned on the right side twine wouldn't feed at all, so we couldn't even make a banana bale. What do we need to look at here?
walter
03-02-2004 11:48:02
 Re: IH 46 Baler in reply to Steve(OR), 03-02-2004 11:32:31
You must straighten the pto shaft to bale. there are pins under the large fly wheel you remove one and pull the baler tounge straight and put the pin in place to hold it. The bend is just to get it through narrow places. Curved bales come from tension inbalances or sometimes from a small windrow feeding in to one side of the chamber. Experiment with your line tensions and make sure you don't have round baler twine in it. Hope this helps.
walter
