544 Farmall Loader Hydraulics
Stan Skowronek
02-29-2004 15:18:17
I just mounted up a 2350 loader on my 544. The loader was run from the remotes, originally. However, I only have one remote. I do have a Prince loader valve w/ a relief. Where should I tap in to so the unloading valve works right? Or should I pop for another remote set up? I already own the loader valve. Any opinions would be helpful. I called one used parts dealer for a price on an inner remote, he must have thought I needed the gold plated one. Thanks, Stan S.
bill
02-29-2004 18:51:11
 Re: 544 Farmall Loader Hydraulics in reply to Stan Skowronek, 02-29-2004 15:18:17
i run a 2250 loader on my 656 from 1 remote. go from the pressure side of your 544 remote (top outlet) to the "in" port on the prince valve, and go from the "out" port back to the bottom outlet on the 544. you'll have to lock the hyd handle back to make the prince valve work. downside is you have to unhook the loader to use remote on a pulled implement. i keep the engine speed to half throttle with the handle locked back to avoid too much pressure in loader valve circuit.
Mac
02-29-2004 16:36:15
If I understand correct you're talking of 2 seperate valves, 1 for lift and other for bucket . The best way to go would be a two spool valve using the one remote you have. I was quoted $1300 for rebuilt remote for my tractor(platinum model?). I think Prince has 2 spool with float for $150 or so. Or for the ultimate in loader performance (super fast)is a front pump (23gpm @ 220rpm on mine)that you can run any number of things from with flow dividers or selector valves (PrinceDirect $30-$40)
