farmall (h) specs ?
Jonathan Mirgon
02-28-2004 19:21:39
looking for head tourque and valve lash spec for a 42 (h) Thanks for your help !
riverbend
02-29-2004 16:24:06
 Re: farmall (h) specs ? in reply to Jonathan Mirgon, 02-28-2004 19:21:39
A manual is a good idea, it saves on comments.
The head nuts should be torqued to 70 ft. lbs. done in a spiral pattern starting from the center, in several steps i.e. 50#, 60#, 70#. Keep going around until every nut holds 70 ft. lbs. It will take several rounds. Run it for a couple hours at operating temperature and re-torque the head. Valve adjustment is .017" hot. Try .018 cold. Readjust the valves after you re-torque the head.
CNKS
02-28-2004 19:27:08
I could look it up, but go to "tune up specs" in www.weberstractorworks.com
