Super A carb problem--gas drip
Glen Thibodeaux
02-23-2004 19:01:56
Problem: When engine is not running and the value is open on fuel bowl gas will drip from the bottom of the carb.I think I'm having a problem with the needle value not sealing/seating. The float moves freely and seems to be OK. I even tried setting the float level lower(less fuel in bowl). I don't see any trash in the needle value area. Bad carb Kit? Any ideas????
DON
02-24-2004 09:08:38
 Re: Super A carb problem--gas drip in reply to Glen Thibodeaux, 02-23-2004 19:01:56
Glen I have been around letter series tractors for over 50 years. When it comes to seep or very slight drip from carb while not running they fall into 2 catergories them that do and them that will sooner or later. You can probaly stop leak but most likely it will come back. Shutting valve at sediment bowl when parking tractor is best solution in my opinion.
Glen
02-24-2004 09:16:24
 Re: Re: Super A carb problem--gas drip in reply to DON, 02-24-2004 09:08:38
Are some carb kits better than others? I used a kit from my local auto parts house (Car Quest), should I have used another name brand?
Glen
02-24-2004 08:19:31
Thanks for all of the solutions to my problem, I'll try them all.
Glen
Ben in KY
02-24-2004 05:59:01
Any rust in the fuel system ? All it takes is one little speck of rust on the needle valve to cause it to leak.
Terry Erickson
02-23-2004 20:55:09
Glen I have the same problem with my 47 A, have replaced needle and seat and adjusted float countless times. I hope to get some suggestions on how to rectify this problem.I have a Zenith carburator. Thanks for any reply's from only in Canada A Farmall owner.
Farmer Bob
02-23-2004 20:42:26
Most likely your needle valve is not seating in the seat like it should. There could be a very small burr on the seat or a worn needle valve but it sounds like you recently put in a new carb kit. Another item is check to ensure the float is not leaking allowing fuel to get inside the float causing it to sink and opening up the needle valve. I'd try another needle and seat.
Bob
02-23-2004 23:02:28
 Re: Re: Super A carb problem--gas drip in reply to Farmer Bob, 02-23-2004 20:42:26
One possible SIMPLE fix is to tighten the seat tighter than HECK into the carburetor top, making sure there is a good gasket in place, and using a good screwdriver of adequate width.
