Order Farmall Cub Parts Online
Hard starting 49 Cub
Red 4 ever
01-02-2004 13:59:58
When I try to start the cub cold it acts like it is only hitting on one cylinder and is all but flooded (gas will be dripping from the carburetor) when it does finally start, and miss for a while then run fine. When I try to start it warm, if it does start it misses for a few seconds then seems to run fine. After the problem started I have installed a needle and seat. new spark plugs and cheaked the points in the magneto
49 Cubber!
01-02-2004 14:33:23
 Re: Hard starting 49 Cub in reply to Red 4 ever, 01-02-2004 13:59:58
Did you set the float when you installed the needle and seat.My Cub was doing that when I first got it,and thats all it was.
Red 4 ever
01-02-2004 17:21:19
 Re: Re: Hard starting 49 Cub in reply to 49 Cubber! , 01-02-2004 14:33:23
Yes, I checked the float setting acording to the ITT book and it measured 1-13/32
Tommy H
01-02-2004 14:09:47
I had a little Tecumseh lawn mower engine do something like that, amazingly it was a badly carboned head, and dirty valves.
It would turn over quickly, and almost not catch, then it would catch, and run rich for a bit, smelled alot like gas, then it would run ok. Hot or cold.
Id make sure it isnt something else first, but it sounds like a badly carboned head to me, or bad plug wires.
