Fast Hitch off a 460
Gibby
12-11-2003 21:01:22
Will a fast hitch off a 460 fit a 560?
Thanks
Dave
Dave560
12-12-2003 19:19:21
 Re: Fast Hitch off a 460 in reply to Gibby, 12-11-2003 21:01:22
I have mounted a 460 fast hitch on a 560. You need to change the two curved mounting brackets that go around the left and right sides of the rear end, and the front mounting point that bolts under the belly. The curved pieces and the front mounting triangle are smaller on a 460, but everything else is the same. For me it was cheaper to buy the 3 pieces than to buy another Fast hitch, since I already had the 460 Fast hitch.
Gibby
12-12-2003 09:50:22
Thanks
Dave
Hugh MacKay
12-12-2003 02:23:53
Gibby: Don is right, the reason being chassis is a different size on the two tractor groups.
Don
12-11-2003 22:00:59
No. 460 fits a 300 or 350. 560 fits smta,400,450. hope this helps
